Use of Valuelist for filling chart
Joen
Post by Joen » Fri Jul 16, 2004 10:34 am
At the moment I'm using fastline.addrealtime. But in some cases I would need even higher performance. My question is can I use the valuelists for adding points to the chart to get higher performance? Or can they only be used for changing values while there are already values in the lists?
Joen
Post by Pep » Wed Jul 21, 2004 1:24 am
Hi Joen,
the only way to add data to the Chart using the IValueList.ValueSource
property (Plese see more details in the Help File).
