Chart resizing on visible series
Raymond
Post by Raymond » Fri Oct 02, 2009 12:34 am
I am wondering if it is possible to resize the margins based on visible series. Suppose I have 2 series: One with Y-value of 24 and the other with Y-value of 1000, and I only want the series with Y-value of 24 to be visible; so the chart's axes will be around the value 24, and not 24 - 1000.
Raymond
Re: Chart resizing on visible series
Post by Yeray » Fri Oct 02, 2009 9:55 am
Hi Raymond,
If you have a whole series that you don't want to be shown, you can simply deactivate it.
If you want to show both series but defining your axis minimum and maximum, you can use the axis function SetMinMax()
Raymond
Post by Raymond » Fri Oct 02, 2009 5:36 pm
The SetMinMax work for line series. However, for bar series, whenever I do SetMinMax, the bar's width becomes a thin line. Is there another way to do it with bar series?
Post by Yeray » Mon Oct 05, 2009 7:15 am
Hi Raymond,
What exact version are you using? Are you using the latest downloadable at customers area?
Raymond
Post by Raymond » Mon Oct 05, 2009 5:00 pm
I am using version 8.0.0.6.11825. I believe that is the latest version.
To duplicate:
- Start with empty chart
- Add bar series with just 1 value
- Set minimum to -1 and maximum to 1
At this point, the bar should become a thin vertical line
Post by Yeray » Tue Oct 06, 2009 9:55 am
Hi Raymond,
Yes, I can see now the problem. I understood that you were setting the left axis.
I've found that there is a similar problem in the wish list so I've updated its description to include this specific issue (TV52014436).
