User Calculated Chart
Guilz
Post by Guilz » Thu Oct 01, 2009 1:55 pm
Is it possible to add user calculated chart ?
ie: I have 2 charts. I want a new chart (chart3) who is the difference between Chart1 and Chart2.
If I add new point in Chart 1 and Chart2, I want Chart3 reflecting this change automatically.
Does it exist a functionnality of Teechart to add chart based on a user formula (in my case it is a difference but I would like to specify my own formula ex Chart1 + 0.75485*Chart2 ...
Thanks for your help :D
Guilz
Re: User Calculated Chart
Post by Narcís » Fri Oct 02, 2009 8:15 am
Hi Guilz,
Yes, there are subtract and y=f(x) functions. Please have a look at the All Features\Welcome!\Functions examples in the features demo and read tutorial 7. Demo and tutorials are available at TeeChart's program group.
Guilz
Post by Guilz » Fri Oct 02, 2009 8:33 am
Hi Narcis,
y=f(x) is not what I'am looking for :?
CalculateMany Function is used to calculate function result if multiple series can be datasource, it is what i am looking for :D
Tell me if I'm wrong but the CalculateMany function is not available for Teechart ActiveX but only for VCL...
Guilz
Post by Yeray » Fri Oct 02, 2009 10:22 am
Hi Guilz,
Note that CalculateMany function is a function present into some TeeChart functions.
Please, try to explain what are you exactly trying to do here and we'll try to suggest you the best way we can find to achieve it.
Guilz
Post by Guilz » Fri Oct 02, 2009 10:36 am
Yeray,
I have 1 chart with 2 series (S1 and S2).
I want to add a new serie S3 reflecting changes of S1 and S2 by a function like S3= S1-S2 (*)
If a new point is added to S1 and S2, S3 must automaticaly reflect this change and add the new calculated point defined by the formula (*)
Hope it is help you to understand what I am looking for :D
Guilz
Post by Yeray » Fri Oct 02, 2009 11:13 am
Hi Guilz,
I think I agree with Narcís. If I understood well you are trying to do something as follows:
Private Sub Command1_Click()
  Dim diff As Double
  diff = TChart1.Series(0).YValues.Maximum - TChart1.Series(0).YValues.Minimum
  TChart1.Series(0).Add (Rnd * diff / 5) - diff / 10 + TChart1.Series(0).YValues.Minimum, "", clTeeColor
  diff = TChart1.Series(1).YValues.Maximum - TChart1.Series(1).YValues.Minimum
  TChart1.Series(1).Add (Rnd * diff / 5) - diff / 10 + TChart1.Series(1).YValues.Minimum, "", clTeeColor
  TChart1.Series(2).CheckDataSource
  TChart1.Axis.Bottom.SetMinMax 0, TChart1.Series(0).Count - 1
Private Sub Form_Load()
  TeeCommander1.Chart = TChart1
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scPoint
  TChart1.AddSeries scLine
  TChart1.Series(0).FillSampleValues 25
  TChart1.Series(1).FillSampleValues 25
  TChart1.Series(2).SetFunction tfCustom
  TChart1.Series(2).DataSource = "Series0,Series1"
Private Sub TChart1_OnFunctionCalculate(ByVal SeriesIndex As Long, ByVal X As Double, Y As Double)
  Y = TChart1.Series(0).YValues.Value(X) - TChart1.Series(1).YValues.Value(X)
Guilz
Post by Guilz » Fri Oct 02, 2009 11:21 am
Fantastic Yeray, it is exactly what I was looking for :wink:
thanks a lot
Guilz
