scColorGrid minimum and maximum colors
jacques
Post by jacques » Mon Sep 21, 2009 7:32 am
I am using a scColorGrid. The control scales the colors automatically with regards the minimum and maximum value that is transferred to the plot.
If I transfer data between 10 and 210 to a plot those seem to be the values used to determine minimum and maximum colors.
I would however like to set the menimum to 0 and the maximum to 255.
Is that possible?
JB
Re: scColorGrid minimum and maximum colors
Post by Yeray » Mon Sep 21, 2009 1:57 pm
Hi JB,
In that case you can set palette minimum:
    TChart1.AddSeries scColorGrid
    TChart1.Series(0).FillSampleValues 10
    TChart1.Series(0).asColorGrid.UseColorRange = False
    TChart1.Series(0).asColorGrid.UsePalette = True
    TChart1.Series(0).asColorGrid.UsePaletteMin = True
    TChart1.Series(0).asColorGrid.PaletteMin = 0
Or you should define your custom colour palette as shown here
