Release build scColorGrid does not work properly
Re: Release build scColorGrid does not work properly
Post by Yeray » Thu Jul 30, 2009 7:24 am
Hi Jacques,
I meant that you could try generating new VC++ classes as is explained in the link above, or you could try forcing the classes provided with the 8.0.0.6 to be used.
The TeeChart installer doesn't change your project's references.
jacques
Post by jacques » Mon Aug 03, 2009 8:18 am
I used the latest installer and used the C files that came with the installer.
I am willing to try and recreate the files but VC 6 and VS2008 differ, could you explain how to do it in VS2008
JB
Post by Yeray » Mon Aug 10, 2009 1:11 pm
Hi Jacques,
I've been testing a little bit more with your application and I've seen that all your series YValues are 0. So I supposed that there were a mistake in the series population procedure and changing the for loop where you add elements to your array for the following, it seems to work fine here:
    for(long i = 0; i < numPoints; i++) {
		//plotData.PutElement(&i, (double *)(&i));
		double val = i;
		plotData.PutElement(&i, &(val));
jacques
Post by jacques » Tue Aug 11, 2009 9:19 am
Thanks, its working.
JB
