Hi Alex,
Thanks for the information. AFAIK you are the first customer to report this issue. We will investigate possible solutions for future releases.
TeeChart7.ocx fails to register on some Vista machines
Re: TeeChart7.ocx fails to register on some Vista machines
I am observing this on both Windows 2008 server and Windows 7.
The problem is actually worse for me than described above as when I restart the print spooler it only fixes the problem temporarily.
I.E Within a few hours I need to stop the print spooler again.
Hi dineena,
Have you tried downloading and using the Microsoft patch Alex posted?
We did this and it seemed to fix the problem. However within a day the problem reoccured again.
The only way that our application can now function(with the TeeChart elements) on these machines is to have the print spooler permanently stopped.
Same thing occurs when we install TeeChart8 on these machines
