License Activation failed during install latest TeeChart 2023
Post by 8355 » Fri May 26, 2023 12:25 pm
Hi Team,
I am unable to install TeeChart Pro ActiveX(TeeChart2023_0_3_20_ActiveX3264.exe) on my server machine. Getting below error, Please let me know how to proceed ,License is active and valid
Error while activating license:
12029 A connection with the server could not be established
Online License activation has failed.
Thanks!
Srikanth Ananthoju
Re: License Activation failed during install latest TeeChart 2023
Post by Yeray » Mon May 29, 2023 11:13 am
Hello Srikanth Ananthoju,
Maybe the server was temporally down. Could you please give it another try?
8355
Post by 8355 » Mon Jul 10, 2023 6:54 am
I've tried again,still same issue.
Post by Yeray » Mon Jul 10, 2023 12:51 pm
Try replying "No" and try the online activation a second time without closing the installer.
If it still fails, try replying "Yes" and follow the instructions. It should give you a code you could use to activate the installation through the activation form.
