Rendering in RTL Environment (Hebrew)
LAL
Post by LAL » Thu Jul 31, 2014 9:59 pm
Using v8 in Hebrew Windows my chart is being rendered backwards.
Example Image
It looks as if the chart is rendered normally (i.e. LTR) and then simply flipped RTL with a BitBLt or something. This is incorrect, the chart should be rendered LTR, as should the arabic numerals.
Only the Hebrew text should be rendered RTL.
Is there an option to prevent this, or is it a bug?
Re: Rendering in RTL Environment (Hebrew)
Post by Yeray » Mon Aug 04, 2014 11:54 am
Can you please check if this is still reproducible with the latest TeeChart version?
http://www.steema.com/download/ax
