[repost] How to draw 3D chart?
Woon
Post by Woon » Mon Jul 21, 2014 7:48 am
hi~ I'm Woon
i want to draw 3D Chart.
but i don't know how to draw chart.
i have not any reference of teechart .
so i want to example source.
i draw to 3D graph about the image pixel value
if 3 Points is (x = 0, y = 5, z = 7), (x = 2, y = 3, z = 10), (x = 4, y = 1, z = 3)
i wish to draw 3D bar Graph that x, y Axis is bottom Plane, and z Axis is Value.
is that possible?
i will wait to your answer.
thank you.
Re: How to draw 3D chart?
Post by Christopher » Mon Jul 21, 2014 9:08 am
Hello Woon.
Woon wrote:hi~ I'm Woon
You should have TeeChart installed on your machine in a location similar to this one:
%Program Files%\Steema Software\Steema TeeChart for .NET 2014 4.1.2014.05090
There are many example of how to use TeeChart you can see by running TeeChartNetExamples.exe, which is under this folder:
%Program Files%\Steema Software\Steema TeeChart for .NET 2014 4.1.2014.05090\Examples\DemoProject\bin\ExecutableDemo
Woon
Post by Woon » Mon Jul 21, 2014 11:57 pm
hi~ I'm woon.
thank you for your answer
Now, i used to TeeChart8ActiveX.
i can find this folder
C:\Program Files\Steema Software\TeeChart Pro v8 ActiveX Control\Examples
but i can't find 3D Chart Examples.
so i want to get the Examples from you.
Post by Christopher » Tue Jul 22, 2014 9:19 am
Hello Woon,
I have moved your post to the ActiveX forum where the ActiveX team will be happy to answer your questions.
Re: [repost] How to draw 3D chart?
Post by Pep » Wed Jul 23, 2014 7:35 am
Hello Woon,
have you looked at the Bar 3D examples you can find into the TeeChartFeatures Demo, which is included into the TeeChart ActiveX installer ?
You can find them at : All Features -> Welcome -> Chart Styles -> Other -> Bar 3D.
Please take a look at the examples and if you still need help on this let us know.
Woon
Post by Woon » Thu Jul 24, 2014 2:48 am
hi~ i'm woon.
Sorry, I can't find the TeeChartFeatures Demo.
i installed TeeChart from the file which is downloaded the download page of your website.
and i attached three picture files that i want to draw using TeeChart.
is that possible?
if you have check that, I am enormously grateful to you.
3d bar2.JPG (12.75 KiB) Viewed 35833 times
3d bar1.JPG (36.54 KiB) Viewed 35837 times
3d bar.JPG (55.78 KiB) Viewed 35835 times
Post by Pep » Thu Jul 24, 2014 12:52 pm
Hello Woon,
with the TeeChart ActiveX and VB code you could make use of the Tower Series Chart and then change its aspect (orthogonal, zoom, rotated, 3dpercent, axis..). A simple example could be :
Private Sub Form_Load()
TeeCommander1.Chart = TChart1
With TChart1
    .AddSeries scTower
    .Series(0).asTower.AddXYZ 0, 5, 7, "", clTeeColor
    .Series(0).asTower.AddXYZ 2, 3, 10, "", clTeeColor
    .Series(0).asTower.AddXYZ 4, 1, 3, "", clTeeColor
    .Aspect.Chart3DPercent = 100
    .Aspect.Orthogonal = False
End With
Woon
Post by Woon » Thu Jul 24, 2014 11:59 pm
hi~
Thank you for your answer.
Now I use to C++.
I try to change from VB Code to C++ Code, but I failed
So I need C++ sample code.
Post by Pep » Mon Jul 28, 2014 6:33 am
Hello Woon,
vc++ code should be something like :
   m_chart.AddSeries(44); // tower
   m_chart.Series(0).GetasTower().AddXYZ(0, 5, 7, "", clTeeColor);
   m_chart.Series(0).GetasTower().AddXYZ(2, 3, 10, "", clTeeColor);
   m_chart.Series(0).GetasTower().AddXYZ(4, 1, 3, "", clTeeColor);
   m_chart.GetAspect().setChart3DPercent (100);
   m_chart.GetAspect().setOrthogonal(False);
Woon
Post by Woon » Tue Jul 29, 2014 7:19 am
Hi ~
I have a mistake. sorry.
I just have Setting of Teechart in OnInitDialog() that is my mistake.
but Now, i know how to use TeeChart. I call a event fuction after then Teechart is drawed.
I'm sorry to bother you. Thank you.
Post by Pep » Tue Jul 29, 2014 8:58 am
great ! I'm glat to hear all is working fine now.
Do not hesitate to contact us in the case we can be of any further help.
