Hi there~!
I developed the application with TeeChart 2011.ocx and VS2008 MFC.
I displayed the chart through OpenGL interface every second.
And I stored the chart numeric data as *.csv files at HDD.
So it show the chart when user clicked specific time list to linked csv file.
But here is trouble portion.
OpenGL Chart display normal and successful at first time.
I create dialog with TeeChart control and show the chart which user clicked specific time. It works good!
But well-displayed chart with running background is trouble.
Label and Title of chart is disappear!!
This chart repaint every second. Why disappear this well-displayed label and title??
I'll wait for your reply.
Thanks~
Label and Title is disappear when OpenGL is redraw
Re: Label and Title is disappear when OpenGL is redraw
If the series or the walls aren't overlapping these texts, I don't see why they should disappear.
I've tried to reproduce the problem but it seems to work as expected for me here. Could you please arrange a simple example project we can run as-is to reproduce the problem here?
I attached sample executable file.
The yellow chart window appear when you double click "LabelMissing.exe".
And the red chart window appear when you click "Create Another Window" button.
And the red chart window destroy when you click "Terminate Another Window" button.
Bingo!! You can see that yellow chart's title and label is disappear.
I'll explain the inner code routine below
Window Initialize -> Timer(trigger every seconds) turn on -> Chart will add data at timer event routine
These steps(Window initialize, Timer Set, Timer event process) are same routine adapted both MainWindow(LabelMissing) and Sub Window(NewLabelMissing).
1. Window Initialize ( Window create routine is execute 1 time)
2.Timer Routine
After Window initialize, SetTimer(timer id, 1 second)
3. Timer event Routine (Execute every 1 second)
Push "Create Another Window" button
Push "Terminate Another Window" button
if (m_tctMain.GetSeriesCount() == 0)
long index = m_tctMain.AddSeries(scTower);
CSeries cSeries = m_tctMain.Series(index);
cSeries.GetAsTower().SetTowerStyle(tsCube);
cSeries.GetAsTower().SetUseOrigin(TRUE);
m_tctMain.SetTheme(ctBlackIsBack, cpOpera);
m_tctMain.GetPanel().GetGradient().SetVisible(FALSE);
m_tctMain.GetPanel().SetColor(RGB(0,0,0));
m_tctMain.GetPanel().SetMarginTop(0);
m_tctMain.GetZoom().SetEnable(FALSE);
m_tctMain.GetScroll().SetEnable(FALSE);
m_tctMain.GetHeader().Show();
m_tctMain.GetHeader().SetCaption(_T("Main Chart"));
m_tctMain.GetHeader().SetCustomPosition(TRUE);
m_tctMain.GetHeader().SetLeft(10);
m_tctMain.GetHeader().SetTop(10);
m_tctMain.GetHeader().GetFont().SetBold(TRUE);
m_tctMain.GetLegend().SetVisible(FALSE);
m_tctMain.GetAspect().SetView3D(TRUE);
m_tctMain.GetAspect().SetOrthogonal(FALSE);
m_tctMain.GetAspect().SetChart3DPercent(100);
m_tctMain.GetAspect().SetZoom(90);
m_tctMain.GetAspect().SetRotation(325);
m_tctMain.GetAspect().SetElevation(345);
m_tctMain.GetAspect().SetPerspective(0);
m_tctMain.GetAspect().GetOpenGL().SetActive(TRUE);
//x axis setting
m_tctMain.GetAxis().GetBottom().SetAutomatic(FALSE);
m_tctMain.GetAxis().GetBottom().SetMaximum(10);
m_tctMain.GetAxis().GetBottom().SetMinimum(0);
//y axis setting
m_tctMain.GetAxis().GetLeft().SetAutomatic(FALSE);
m_tctMain.GetAxis().GetLeft().SetMinimum(0);
m_tctMain.GetAxis().GetLeft().SetMaximum(10);
//z axis setting
m_tctMain.GetAxis().GetDepth().SetVisible(TRUE);
m_tctMain.GetAxis().GetDepth().SetAutomatic(FALSE);
m_tctMain.GetAxis().GetDepth().SetMaximum(10);
m_tctMain.GetAxis().GetDepth().SetMinimum(0);
m_tctMain.GetWalls().GetBack().SetVisible(TRUE);
m_tctMain.GetWalls().GetBack().GetGradient().SetVisible(FALSE);
m_tctMain.GetWalls().GetBack().SetColor(RGB(90,90,90));
m_tctMain.GetWalls().GetLeft().SetVisible(TRUE);
m_tctMain.GetWalls().GetLeft().SetColor(RGB(65,65,65));
m_tctMain.GetWalls().GetLeft().GetPen().SetVisible(FALSE);
m_tctMain.GetWalls().GetBottom().SetVisible(TRUE);
m_tctMain.GetWalls().GetBottom().SetSize(1);
m_tctMain.RemoveAllSeries(); //For memory release
CSeries cSeries = m_tctMain.Series(0);
for (int nPeriod=0; nPeriod<10; nPeriod++)
for (int nPhase=0; nPhase<10; nPhase++)
int nData = rand() % 10;
cSeries.GetAsTower().AddXYZ(nPeriod, nData , nPhase, _T(""), RGB(255,255,0));
CRedChartDlg* pNew = new CRedChartDlg;
if(pNew)
pNew->Create(IDD_NEWDLG, this);
pNew->ShowWindow(SW_SHOW);
if(pNew)
pNew->DestroyWindow();
delete pNew;
pNew = NULL;
- LabelMissing.zip
- Sample Executable file
- (68.91 KiB) Downloaded 1033 times
Hello Pine,
Can you please, send us your complete project, not only the .exe, so seems in your code has lost variables and we can not reproduce your problems here?
Hello sandra!
I can't attach the sample project file because file size limit (under 512KB ㅠ_ㅠ)
So I'll afford link.. Please contact this link and download zip file.
Link is http://sdrv.ms/PYjLGF
Hello again Sandra.
If you can't download above line, I send to you E-mail message.
So you can check code in my project.
Thanks~!
Thanks~!
Hello pine,
We have investigating your problem ans I answer you asap.
Hello pine,
Sorry for the delay. We have had many tests and we consider your problem as a bug with number[TA05016415]. We will try to fix it to upcoming versions of TeeChartActivex. At the moment, you can enable and disable the TeeOpenGl or Redraw the Chart because the labels appears.
