I use the TeeChart Pro ActiveX , and it will occurs a error when showing the chart. The attachment is the screenshot of the error. How could I solve this problem, Thanks!
TeeChart Pro ActiveX problem
- teechart问题.jpg (75.52 KiB) Viewed 5736 times
Re: TeeChart Pro ActiveX problem
The error message doesn't give us too much information. Could you please explain in what situation you get it? Or even better, could you please arrange a simple example project we can run as-is to reproduce the problem here?
