Cursor Tool & Clipping
Rossmc
Post by Rossmc » Wed Dec 08, 2004 10:11 am
Drawing a financial chart on default axes, I then add a volume graph on a custom axis directly below and sharing the same bottom axis. When I add a vertical teeCursor it only appears in the primary graph not for the custom axis. Is there a way to make the line simply extend for the full length of the Chart canvas? Hope this makes sense.
Rossmc
'Clipping Nodes'
Post by Rossmc » Wed Dec 08, 2004 10:14 am
Sorry, forgot to add my question about 'clipping'. If user clicks on a series line I want to show nodes along the line to indicate it is the selectedf series, like you would see in a drawing app. Is there an easy way to do this?
Post by Pep » Mon Dec 13, 2004 8:10 am
The best way to do this is to use another Cursor tool for the other Serie like in the following code :
Private Sub Form_Load()
With TChart1
    .Aspect.View3D = False
    .AddSeries scCandle
    .Series(0).FillSampleValues (25)
    .Axis.Left.EndPosition = 75
    .AddSeries scVolume
    .Series(1).FillSampleValues (25)
    a = .Axis.AddCustom(False)
    .Axis.Custom(a).StartPosition = 75
    .Axis.Custom(a).EndPosition = 100
    .Series(1).VerticalAxisCustom = a
    .Tools.Add tcCursor
    .Tools.Items(0).asTeeCursor.Series = TChart1.Series(0)
    .Tools.Items(0).asTeeCursor.Style = cssVertical
    .Tools.Items(0).asTeeCursor.FollowMouse = True
    .Tools.Add tcCursor
    .Tools.Items(1).asTeeCursor.Series = TChart1.Series(1)
    .Tools.Items(1).asTeeCursor.Style = cssVertical
    .Tools.Items(1).asTeeCursor.FollowMouse = True
End With
Private Sub TChart1_OnCursorToolChange(ByVal Tool As Long, ByVal X As Long, ByVal Y As Long, ByVal XVal As Double, ByVal YVal As Double, ByVal Series As Long, ByVal ValueIndex As Long)
If Tool = 0 Then
    TChart1.Tools.Items(1).asTeeCursor.XVal = TChart1.Tools.Items(0).asTeeCursor.XVal
Else
    TChart1.Tools.Items(0).asTeeCursor.XVal = TChart1.Tools.Items(1).asTeeCursor.XVal
End If
or use the Canvas techniques to draw a line over the Chart.
Post by Pep » Mon Dec 13, 2004 8:16 am
How about using the SelectorTool (only avaiable at design time for the momment) ?
It will be available at runtime for the next maintenance releases.
