I've used TeeChart AX v8 to create a window that can be configured to contain up to 18 plots in a grid. My users would like to see all of the plots in a column drawn with aligned vertical axes. That is, for the far left and rights sides of the plots to be drawn at the same screen-wise X coordinate. If you see the attached pictures: A is how the test plots look by default and B is how it is desired for them to look. So essentially what I'm asking is: Given the two plots shown in A, what is the best way to make them look like B?
Right now, I figure can use the Panel interface to adjust the margins and achieve the result I want but those values are relative. I can't figure out how to find the exact screen coordinates of the left and right vertical bounds in order to determine how to set those margins.
Matt
Aligning the Vertical Axes of Two Charts
- Before
- A.gif (14.65 KiB) Viewed 4766 times
- After
- B.gif (16.75 KiB) Viewed 4749 times
Re: Aligning the Vertical Axes of Two Charts
Hi Matt,
This was discussed here some time ago. If you find any problem translating the code from delphi, don't hesitate to let us know.
