limit of line series on a chart
Andras
Post by Andras » Fri Oct 01, 2004 7:00 pm
Dear Support
I have a very simple question: is there a limit how many line (or point, or both) series I can put on a chart?
Tx, regards
Andras
Post by Pep » Sat Oct 02, 2004 8:24 am
Hi Andras,
maximum 134217727 points per Series and same number of Series per Chart.
Andras
Post by Andras » Sun Oct 03, 2004 2:21 am
Pep wrote:Hi Andras,
Gr8!! I'm relaxed, this will be certainly enough for a while :D
Tx Pep, regards
Andras
Neil
Post by Neil » Fri Oct 08, 2004 11:44 am
Something to bear in mind...
If this is a real time graph and you are not using FastLineSeries it will be very slow to plot a graph with this many items.
My application generates around 20 items per second, with a new series every 20 seconds When using LineSeries, I couldn't show 1000 series of 100 items in real time.
The way I overcame this was when there are more than 100 series, remove every other series. In this way the display only has to show a maximum of 100*100*25 points.
YMMV
Neil
Post by Pep » Fri Oct 08, 2004 4:13 pm
you can find a good technical article about the Real-Time charting here.
It's for VCL version but could be applicable in the ActiveX version.
