Problem with right and left axis
Daniel
Post by Daniel » Mon Sep 21, 2009 5:49 pm
Hi!!
Actually I use Teechart 7 version and Visual Basic 6. I need draw two series, one of them a bar style in left axis, and the other line style in right axis. I need a graph similar to image (attach), is this possible? And I can set the number of points in the scale? (In this example 6 points), because when set min and max values por left and right scale, the rght scale don't start in the bottom axis, and the graph have difent lines in left and riight axis. Thanks in advance
Example
Re: Problem with right and left axis
Post by Yeray » Tue Sep 22, 2009 7:50 am
Hi Daniel,
You could use custom labels to do this. For example, this seems to end similar than what you described:
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scBar
  TChart1.AddSeries scLine
  Dim i As Integer
  For i = 0 To 25
    TChart1.Series(0).Add Rnd * 5, "", clTeeColor
    TChart1.Series(1).Add (Rnd * 0.25) + 2.6, "", clTeeColor
  Next i
  TChart1.Series(0).Marks.Visible = False
  TChart1.Series(0).asBar.BarWidthPercent = 25
  TChart1.Series(1).Pen.Width = 2
  TChart1.Series(0).VerticalAxis = aLeftAxis
  TChart1.Series(1).VerticalAxis = aRightAxis
  TChart1.Axis.Left.SetMinMax 0, 6
  TChart1.Axis.Right.SetMinMax 2.5, 2.9
Private Sub DrawRighAxisCustomLabels()
  Dim i As Integer
  Dim YValue As Double
  With TChart1.Axis
    .Right.Labels.Clear
    For i = 0 To .Left.Labels.Count - 1
      YValue = .Right.CalcPosPoint(.Left.CalcYPosValue(.Left.Labels.Item(i).Value))
      .Right.Labels.Add YValue, Format$(YValue, "#.###")
    Next i
  End With
Daniel
Post by Daniel » Wed Sep 23, 2009 4:36 pm
Thanks for your reply. I try your solution, but not fix my problem. I need, equal lines in right and left axis, i will attach an image with the example. And other question, I can set the number of intervals in the graph? I changed the increment value in the left and right axis calculating this value (in other example), but the right axis not start in the bottom axis, and the lines in left and right axis is not equal. Thanks for your time and patience.
Graph Demo
Post by Yeray » Thu Sep 24, 2009 9:24 am
Hi Daniel,
Excuse me. I missed a line at the end of Form_Load method:
Now I corrected the code above too.
Daniel
Post by Daniel » Tue Oct 27, 2009 5:11 pm
Hi Yeray, thanks for your time
I try again, and the problem is the same
Is possible draw a graph like I want?
Daniel
Post by Daniel » Tue Oct 27, 2009 9:13 pm
I want to draw a graph like that.
Thanks in advance
Post by Yeray » Wed Oct 28, 2009 10:09 am
Hi Daniel,
Here is what I'm getting with the code suggested above in TeeChart v8.
I'm afraid I can't think on a way to do this in v7.
Daniel
Post by Daniel » Wed Oct 28, 2009 4:13 pm
Hi Yeray
Is true, I tried in v8 and work fine. Thanks. I'll update my version
I have another two questions
- Is possible create a graph, with comments in a few points? (like picture1)
- If I have a graph with logarithmic scale, how can I controll the number of points in a scale, for example if I want only 3 points (like pincture 2)
Thanks for your time, if this two graphs work fine, I'll update my version asap :D
Thanks in advance
Picture 1
Picture 2
Post by Yeray » Fri Oct 30, 2009 3:42 pm
Hi Daniel,
Daniel wrote:- Is possible create a graph, with comments in a few points? (like picture1)
Yes, you can use annotation tools and you can update their positions at OnAfterDraw event if you want them to be repositioned each time the chart is redrawn.
Daniel wrote:- If I have a graph with logarithmic scale, how can I controll the number of points in a scale, for example if I want only 3 points (like pincture 2)
Do you mean the left axis labels? You can use custom labels, for example:
uses series, teetools;
  Chart1.View3D:=false;
  Chart1.MarginLeft:=10;
  Chart1.AddSeries(TFastLineSeries.Create(self));
  Chart1.Axes.Left.Logarithmic:=true;
  Chart1[0].FillSampleValues(100);
  with Chart1.Axes.Left.Items do
    Clear;
    Add(Chart1[0].YValues.MinValue);
    Add(Chart1[0].YValues.MinValue + Chart1[0].YValues.MaxValue / 2);
    Add(Chart1[0].YValues.MaxValue);
  Chart1.Tools.Add(TAnnotationTool.Create(self));
  (Chart1.Tools[0] as TAnnotationTool).Text:='point 25 info';
  (Chart1.Tools[1] as TAnnotationTool).Text:='point 75 info';
  Chart1.Draw;
  (Chart1.Tools[0] as TAnnotationTool).Left:=Chart1[0].CalcXPos(25);
  (Chart1.Tools[0] as TAnnotationTool).Top:=Chart1[0].CalcYPos(25);
  (Chart1.Tools[1] as TAnnotationTool).Left:=Chart1[0].CalcXPos(75);
  (Chart1.Tools[1] as TAnnotationTool).Top:=Chart1[0].CalcYPos(75);
Daniel
Post by Daniel » Fri Oct 30, 2009 5:10 pm
Thanks Yeray, I'll update my versión ASAP
Could you write to me, an example for anotation tool?
TIA
Daniel
Daniel
Post by Daniel » Fri Oct 30, 2009 5:35 pm
Hi Yeray
Acutally I use Visual Basic 6.
thanks
Post by Yeray » Mon Nov 02, 2009 8:44 am
Hi Daniel,
Here it is the above example translated to VB6:
  TChart1.Panel.MarginLeft = 10
  TChart1.AddSeries scFastLine
  TChart1.Axis.Left.Logarithmic = True
  TChart1.Series(0).FillSampleValues 100
  With TChart1.Axis.Left.Labels
    .Clear
    .Add TChart1.Series(0).YValues.Minimum, Str$(TChart1.Series(0).YValues.Minimum)
    .Add TChart1.Series(0).YValues.Minimum + TChart1.Series(0).YValues.Maximum / 2, Str$(TChart1.Series(0).YValues.Minimum + TChart1.Series(0).YValues.Maximum / 2)
    .Add TChart1.Series(0).YValues.Maximum, Str$(TChart1.Series(0).YValues.Maximum)
  End With
  TChart1.Tools.Add tcAnnotate
  With TChart1.Tools.Items(0).asAnnotation
    .Text = "point 25 info"
    .Callout.Visible = True
    .Callout.Arrow.Visible = True
    .Callout.Style = psNothing
    .Callout.Arrow.Color = vbBlack
  End With
  With TChart1.Tools.Items(1).asAnnotation
    .Text = "point 75 info"
  End With
    .Left = TChart1.Series(0).CalcXPos(25) + 10
    .Top = TChart1.Series(0).CalcYPos(25) + 10
    .Callout.XPosition = TChart1.Series(0).CalcXPos(25)
    .Callout.YPosition = TChart1.Series(0).CalcYPos(25)
  End With
    .Left = TChart1.Series(0).CalcXPos(75) + 10
    .Top = TChart1.Series(0).CalcYPos(75) + 10
    .Callout.XPosition = TChart1.Series(0).CalcXPos(75)
    .Callout.YPosition = TChart1.Series(0).CalcYPos(75)
  End With
Daniel
Post by Daniel » Mon Nov 02, 2009 2:47 pm
That's exact why I need
