Enable Point Style in Graph on Specific Point
Lopes
Post by Lopes » Wed Jun 17, 2009 3:26 pm
I'm Working with Teechart and i need to do one thing.
I'm working with marks to post comments on my Graph, when the user click in one point i enable a TextBox and write some values to the mark, this thing is working OK.
But i want to enable a point style in that mark and not in the entire line...
i used this code but this enable the point in all line
document.getElementById("axChart").Series(0).asLine.Pointer.Visible = True
I Have the X and Y coordinates from the point, i wrote the mark on this:
document.getElementById("axChart").Canvas.TextOut X, Y , "Text"
Now i want to enable a POINT Style on this MArk, it's possible?
thanks
Thiago,
Re: Enable Point Style in Graph on Specific Point
Post by Yeray » Thu Jun 18, 2009 11:52 am
Yes, you could activate the line's pointers and then use OnGetPointerStyle to hide or show the one you would like. Something like this:
Private Sub Form_Load()
  TChart1.AddSeries scLine
  TChart1.Series(0).FillSampleValues 25
  TChart1.Series(0).asLine.Pointer.Visible = True
Private Sub TChart1_OnGetSeriesPointerStyle(ByVal SeriesIndex As Long, ByVal ValueIndex As Long, AStyle As TeeChart.EPointerStyle)
  If ValueIndex = 5 Then
    AStyle = psRectangle
  Else
    AStyle = psNothing
  End If
Lopes
Post by Lopes » Thu Jun 18, 2009 2:16 pm
Hi, when i insert this code i having this error:
        private sub axChart_OnGetSeriesPointerStyle(ByVal SeriesIndex As Long, ByVal ValueIndex As Long, AStyle As TeeChart.EPointerStyle)
          Else
            AStyle = psNothing
          End If
Error: Expected ')'
Error: Object Expected
Lopes
Post by Lopes » Thu Jun 18, 2009 2:57 pm
Strange..
I used other sub to test and return the same error.
Without this code return no errors.
Public Sub axChart_OnGetSeriesMark(ByVal SeriesIndex As Long, ByVal ValueIndex As Long, MarkText As String)
MsgBox SeriesIndex
And there is another example with a sub, this is working OK
		Private Sub axChart_OnMouseDown(ByVal Button, ByVal Shift, ByVal CordX, ByVal CordY)
			grf_X0 = CordX
			grf_Y0 = CordY
Here is my Object:
  <object id="axChart" style="font-weight: 700; z-index: 101; left: 40px; float: left;
                                        width: 984px; top: 224px; height: 401px;" codebase="components/Teechart8.cab#version=8,0,0,1"                                       type="application/x-oleobject" border="1" classid="clsid:B6C10489-FB89-11D4-93C9-006008A7EED4"
                                        name="axChart" viewastext>
                                        <param name="Base64" value="VFBGMAtUQ2hhcnRDaGFydAAETGVmdAIAA1RvcAIABVdpZHRoA9gDBkhlaWdodAPCARFHcmFkaWVu&#13;&#10;dC5FbmRDb2xvcgT6+voAE0dyYWRpZW50LlN0YXJ0Q29sb3IE2+bwABBHcmFkaWVudC5WaXNpYmxl&#13;&#10;CQxNYXJnaW5Cb3R0b20CBQpNYXJnaW5MZWZ0AgELTWFyZ2luUmlnaHQCAQlNYXJnaW5Ub3ACAhFU&#13;&#10;aXRsZS5Gb250LkhlaWdodALwEFRpdGxlLkZvbnQuU3R5bGULBmZzQm9sZAASVGl0bGUuVGV4dC5T&#13;&#10;dHJpbmdzAQYKR3LhZmljbyBwSAAVQm90dG9tQXhpcy5BeGlzLldpZHRoAgEZQm90dG9tQXhpcy5E&#13;&#10;YXRlVGltZUZvcm1hdAYQZGQvTU0veXl5eSBISDptbRdCb3R0b21BeGlzLkdyaWQuVmlzaWJsZQga&#13;&#10;Qm90dG9tQXhpcy5MYWJlbHNNdWx0aUxpbmUJE0xlZnRBeGlzLkF4aXMuV2lkdGgCARBMZWdlbmQu&#13;&#10;QWxpZ25tZW50BwhsYUJvdHRvbRFMZWdlbmQuQ2hlY2tCb3hlcwkWTGVnZW5kLkZvbnRTZXJpZXND&#13;&#10;b2xvcgkSTGVnZW5kLkZyYW1lLkNvbG9yBwZjbEdyYXkZTGVnZW5kLkdyYWRpZW50LkRpcmVjdGlv&#13;&#10;bgcLZ2RUb3BCb3R0b20YTGVnZW5kLkdyYWRpZW50LkVuZENvbG9yBMbG/wAaTGVnZW5kLkdyYWRp&#13;&#10;ZW50LlN0YXJ0Q29sb3IHB2NsV2hpdGUXTGVnZW5kLkdyYWRpZW50LlZpc2libGUJEExlZ2VuZC5U&#13;&#10;ZXh0U3R5bGUHCGx0c1BsYWluEkxlZ2VuZC5WZXJ0U3BhY2luZwIBFFJpZ2h0QXhpcy5BeGlzLldp&#13;&#10;ZHRoAgESVG9wQXhpcy5BeGlzLldpZHRoAgELVmlldzNEV2FsbHMIDVpvb20uQW5pbWF0ZWQJDlpv&#13;&#10;b20uUGVuLkNvbG9yBwdjbEJsYWNrDlpvb20uUGVuLlN0eWxlBwlwc0Rhc2hEb3QKQmV2ZWxPdXRl&#13;&#10;cgcGYnZOb25lCkJldmVsV2lkdGgCAAxQcmludE1hcmdpbnMBAg8CHgIPAh4AAAtUTGluZVNlcmll&#13;&#10;cwdTZXJpZXM0BURlcHRoAgARTWFya3MuQXJyb3dMZW5ndGgCCApNYXJrcy5DbGlwCRZNYXJrcy5H&#13;&#10;cmFkaWVudC5WaXNpYmxlCRBNYXJrcy5TaGFwZVN0eWxlBxFmb3NSb3VuZFJlY3RhbmdsZQtNYXJr&#13;&#10;cy5TdHlsZQcIc21zVmFsdWUNTWFya3MuVmlzaWJsZQgLU2VyaWVzQ29sb3IHBWNsUmVkBVRpdGxl&#13;&#10;BhZwSCBkYSDBZ3VhIGRlIFByb2Nlc3NvC1ZhbHVlRm9ybWF0BgkjLiMjMCwjIyMNQ2xpY2thYmxl&#13;&#10;TGluZQgNTGluZVBlbi5Db2xvcgcFY2xSZWQOUG9pbnRlci5EcmF3M0QIFlBvaW50ZXIuSW5mbGF0&#13;&#10;ZU1hcmdpbnMJDVBvaW50ZXIuU3R5bGUHCXBzRGlhbW9uZA9Qb2ludGVyLlZpc2libGUIEFhWYWx1&#13;&#10;ZXMuRGF0ZVRpbWUJDFhWYWx1ZXMuTmFtZQYBWA1YVmFsdWVzLk9yZGVyBwZsb05vbmUQWVZhbHVl&#13;&#10;cy5EYXRlVGltZQgMWVZhbHVlcy5OYW1lBgFZDVlWYWx1ZXMuT3JkZXIHBmxvTm9uZQAAD1RGYXN0&#13;&#10;TGluZVNlcmllcwdTZXJpZXMwBURlcHRoAgARTWFya3MuQXJyb3dMZW5ndGgCCBZNYXJrcy5HcmFk&#13;&#10;aWVudC5WaXNpYmxlCRBNYXJrcy5TaGFwZVN0eWxlBxFmb3NSb3VuZFJlY3RhbmdsZQtNYXJrcy5T&#13;&#10;dHlsZQcIc21zVmFsdWUNTWFya3MuVmlzaWJsZQgLU2VyaWVzQ29sb3IEAID/AAVUaXRsZQYScEgg&#13;&#10;ZGEgwWd1YSBkbyBMYWdvC1ZhbHVlRm9ybWF0BgkjLiMjMCwjIyMRQXV0b1NjYWxlVmVydEF4aXMI&#13;&#10;DUxpbmVQZW4uQ29sb3IEAID/ABBYVmFsdWVzLkRhdGVUaW1lCQxYVmFsdWVzLk5hbWUGAVgNWFZh&#13;&#10;bHVlcy5PcmRlcgcGbG9Ob25lEFlWYWx1ZXMuRGF0ZVRpbWUIDFlWYWx1ZXMuTmFtZQYBWQ1ZVmFs&#13;&#10;dWVzLk9yZGVyBwZsb05vbmUAAA9URmFzdExpbmVTZXJpZXMHU2VyaWVzMQVEZXB0aAIAEU1hcmtz&#13;&#10;LkFycm93TGVuZ3RoAggWTWFya3MuR3JhZGllbnQuVmlzaWJsZQkQTWFya3MuU2hhcGVTdHlsZQcR&#13;&#10;Zm9zUm91bmRSZWN0YW5nbGULTWFya3MuU3R5bGUHCHNtc1ZhbHVlDU1hcmtzLlZpc2libGUIC1Nl&#13;&#10;cmllc0NvbG9yBADqAAAFVGl0bGUGGnBIIGRhIMFndWEgUGx1dmlhbCBG4WJyaWNhC1ZhbHVlRm9y&#13;&#10;bWF0BgkjLiMjMCwjIyMRQXV0b1NjYWxlVmVydEF4aXMIDUxpbmVQZW4uQ29sb3IEAOoAABBYVmFs&#13;&#10;dWVzLkRhdGVUaW1lCQxYVmFsdWVzLk5hbWUGAVgNWFZhbHVlcy5PcmRlcgcGbG9Ob25lEFlWYWx1&#13;&#10;ZXMuRGF0ZVRpbWUIDFlWYWx1ZXMuTmFtZQYBWQ1ZVmFsdWVzLk9yZGVyBwZsb05vbmUAAA9URmFz&#13;&#10;dExpbmVTZXJpZXMHU2VyaWVzMgVEZXB0aAIAEU1hcmtzLkFycm93TGVuZ3RoAggWTWFya3MuR3Jh&#13;&#10;ZGllbnQuVmlzaWJsZQkQTWFya3MuU2hhcGVTdHlsZQcRZm9zUm91bmRSZWN0YW5nbGULTWFya3Mu&#13;&#10;U3R5bGUHCHNtc1ZhbHVlDU1hcmtzLlZpc2libGUIC1Nlcmllc0NvbG9yBwZjbEdyYXkFVGl0bGUG&#13;&#10;FXBIIGRhIMFndWEgUHV2aWFsIE1TRwtWYWx1ZUZvcm1hdAYJIy4jIzAsIyMjEUF1dG9TY2FsZVZl&#13;&#10;cnRBeGlzCA1MaW5lUGVuLkNvbG9yBwZjbEdyYXkQWFZhbHVlcy5EYXRlVGltZQkMWFZhbHVlcy5O&#13;&#10;YW1lBgFYDVhWYWx1ZXMuT3JkZXIHBmxvTm9uZRBZVmFsdWVzLkRhdGVUaW1lCAxZVmFsdWVzLk5h&#13;&#10;bWUGAVkNWVZhbHVlcy5PcmRlcgcGbG9Ob25lAAALVEN1cnNvclRvb2wAC0ZvbGxvd01vdXNlCQVT&#13;&#10;dHlsZQcLY3NzVmVydGljYWwAAA1UTWFya3NUaXBUb29sCkNoYXJ0VG9vbDALTW91c2VBY3Rpb24H&#13;&#10;CG10bUNsaWNrAAAAAAAAAAIAAAAA/////w==">
                                    </object>
Post by Pep » Fri Jun 19, 2009 4:28 pm
Hello Lopes,
would you be so kind to let us know which environment and language ( vbscript, javascript, etc.. ) are you using ?
Lopes
Post by Lopes » Mon Jun 22, 2009 3:26 pm
vbscript!
regards,
Post by Pep » Tue Jun 23, 2009 4:33 pm
Hi Lopes,
you could use the following code (tested here and works fine) :
Sub TChart1_OnGetSeriesPointerStyle(SeriesIndex, ValueIndex, AStyle)
if ValueIndex = 4 then ' Will change the next pointer 5 due to the vbscript
  TChart1.Series(0).asPoint.Pointer.Style = 1  ' circle
  TChart1.Series(0).asPoint.Pointer.Style = 0
end if
Another way would be to draw your own symbols (or anything else) onto the TeeChart canvas using TeeChart's Canvas drawing methods (into the OnAfterDraw event) exposed in Tutorial 13 - Custom drawing on the Chart Panel.
Lopes
Post by Lopes » Thu Jul 02, 2009 2:05 pm
Alright PEP, the code worked (with no errors)
But nothing happened..
example:
i write a text in a Point:
I want to enable to enable the point style circle on this point with X and Y coordinates.. is possible?
What means ValueIndex in this context?
I put this Sub on my application but doesn´t being called (i put a MsgBox do test) like this:
MsgBox "Test"
end if
Post by Pep » Mon Jul 06, 2009 9:35 am
Hi Lopes,
strange, here the event is called, could you please check if the attached example works fine for you ?
sample.zip
(1.38 KiB) Downloaded 629 times
