Setting Font for TChart Header
nbp
Post by nbp » Wed Sep 17, 2008 4:59 pm
I need to set the Font for the header but can't find a SetFont Property for CTitles. I have the following
e.g.
LOGFONT mlf;
mChart->GetHeader().SetFont(mLf)
does not work (there is no SetFont method for CTitles)
Can someone point me in the right direction?
Post by Narcís » Thu Sep 18, 2008 10:07 am
Hi nbp,
You need to use GetFont().SetName method as in the example I posted here.
nbp
Post by nbp » Fri Feb 13, 2009 8:44 pm
Thanks. SetName() worked for me. Now I want to set the size of the font using the size I get from a CFontDialog but the text on the Chart is very big. I'm using
CFontDialog dlg;
dlg.doModal();
m_Chart->GetHeader().GetFont().SetSize( dlg.GetSize());
I also tried setting the height using the size as follows:
long newSize = m_Chart->GetHeader().GetFont().GetSize() * m_Chart->GetHeader.GetFont().GetPixelsPerInch/72;
m_Chart->GetHeader().GetFont().SetHeight(newSize);
This also produced much larger text than expected...
What property should I be setting?
nbp
Post by nbp » Fri Feb 13, 2009 9:12 pm
Another related question:
How do I initialize a CFontDialog object (MFC) with properties of the Chart Header? Is there an example I can view?
Post by Yeray » Mon Feb 16, 2009 11:50 am
Hi nbp,
Here is an example of how you could set the chart's header font size to be shown at the editor:
	LOGFONT lf;
	memset(&lf, 0, sizeof(LOGFONT));
	CClientDC dc(this);
	lf.lfHeight = -MulDiv(m_Chart1.GetHeader().GetFont().GetSize(), dc.GetDeviceCaps(LOGPIXELSY), 72);
	CFontDialog fdlg(&lf);
    fdlg.DoModal();
