I have use the GetTools().GetItems(0).GetAsAnnotation().GetShape().GetFrame().SetVisible(false), but some mistakes occur when it run.
And some Properties of it ,like setwith() , will call wrong too.
Thank you
the problem with Annotation().GetShape().GetFrame()
which TeeChart Pro version are you using ? I've test it here with the v6.05 and works just fine.
Pep Jorge
http://support.steema.com
yes, you're correct. Them only work fine since TeeChart Pro v6.
Pep Jorge
I think the only way is to setting the values at design time, via Editor.
Pep Jorge
