Setting the Back Image for TChart
nbp
Post by nbp » Tue Oct 28, 2008 10:25 pm
I'm using TChart ActiveX v7. I need to set the BackImage for the chart after the user has selected the image file from a file selector dialog. Is there an example of this? What property of the "Panel" do I set?
m_pChart->GetPanel().Set?????
Post by Narcís » Thu Oct 30, 2008 9:52 am
Hi nbp,
You should use m_Chart1.GetPanel().BackImageLoad() method.
nbp
Post by nbp » Thu Oct 30, 2008 7:42 pm
Thanks. Now I want to retrieve the filename to serialize it - what is the 'Get' method I use to retieve the filename for the image, in order to save it?
Post by Pep » Mon Nov 03, 2008 11:21 am
there's not a method to get the FileName, but it's not required as once you runt the BackImageLoad, the image is part of the TChart component, so the image file i snot required. This means that if you export the Chart to .tee the image is included automatically ( but not as a file ).
