Hello
We are having a problem here with Active Reports and the TeeChart 8 Pro. We are running reports for a QA scheme from a recordset, and all is well until current and archive results are rendered to the graph. This sub ParamGraph is called in the Detail_Format section of AR. The graph skips the current report graph, and renders the following participant's graph on the chart, but reports the correct parameter in the AR fields, also called in the Detail_Format section. We have not seen this before. If we render an individual report, ie, not in a recordset run, all is fine. We have tried moving the graph rendering sub, but to no avail, it has to be in the Detail_Format section to render. So, in a nutshell, Participant 1 has Participant 2 graph rendered, and so on. Any suggestions?
Thank you
David
Active report and TeeChart 8 Pro problem
Hello David,
Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
Hello David,
I'm glad to hear you solved your problem. Did you use v8.0.0.4 release for that? In that version a few changes for Active Reports were made.
Hello Narcis
Sorry for the delay, I have been on vacation.
Yes, I was using the new build 8.0.0.4. However, I have also taken this issue up with Data Dynamics (Active Reports), and it appears that this may be a problem with the Active Report itself. I will await further information from them in this respect.
David
David
