GetAsLine() -> Invalid Type Cast
jonnyg
Post by jonnyg » Wed Apr 23, 2008 5:04 pm
I'm calling:
m_chart.Series(i).Add(series_val, x_axis_label, color);
m_chart.Series(i).GetAsLine();
and getting "Invalid class typecast" during runtime when the GetAsLine() method is called. I'm using the TeeChart Pro Activex Control v8
From Release.txt:
January 2008
v8.0.0.3 Release
Any clue as to why this is happening?
John G[/code]
Post by Narcís » Thu Apr 24, 2008 9:28 am
Hi jonnyg,
This works fine for me here using same TeeChart version as you. Could you please send us a simple example project we can run "as-is" to reproduce the problem here?
You can either post your files a t news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
jonnyg
Post by jonnyg » Mon Apr 28, 2008 6:27 am
I've uploaded InvalidTypeCast.zip for your perusal.
Thanks for your help.
John G
Post by Yeray » Fri May 02, 2008 9:09 am
Hi John,
We think that probably the teechart wrapper classes that your project is trying to use are not up to date. So I recommend you to regenerate them. Here are the steps you should follow:
- create a new dialog based project in mfc
- From the VC++ v6 IDE select "Project":"Add to project":"Components and Controls":"Registered ActiveX Controls" ... select "TeeChart Pro ActiveX Control v8" from the list.
- Accept with "OK" and the VC++ ClassWizard will generate all the classes related to the version of TeeChart registered. You may then re-use those class files in your project.
If this doesn't solve your problem, we'll investigate more
jonnyg
Post by jonnyg » Fri May 02, 2008 2:51 pm
I do not have the VC++ v6 IDE. I only have a license for VS 2005 Pro Edition.
When I create an MFC dialog-based project and add a TeeChart control, no wrapper
classes are created. However once I add a control variable (I named it m_chart)
for the TChart control, the wizard creates one new class named CTchart1, which
inherits CWnd.
Note that when adding the TChart control variable, the ctor for the parent
dialog is modified as follows:
CTChartDlgDlg::CTChartDlgDlg(CWnd* pParent /*=NULL*/)
	: CDialog(CTChartDlgDlg::IDD, pParent)
	, m_chart(0)
	m_hIcon = AfxGetApp()->LoadIcon(IDR_MAINFRAME);
Notice m_chart(0) in the initialization list. This is wrong because there is no
ctor for CTchart1 that takes an int. Can you guys fix that? I see in other posts
that this has caused some trouble for other people as well.
Attempting to use the wizard-created CTchart1 class for my chart object, I'm
forced into casting hell. And ultimately, I end up using the same classes that
caused the original problem, and consequently, I still get the "Invalid class
typecast" error.
void CTChartDlgDlg::InitializeTChart()
	string pre_label("label");
	stringstream label;
	string pre_series("series");
	stringstream series;
	unsigned long color;
	for(int i=0;i<3;i++) {
		m_chart.AddSeries(CTchart1::scPoint);
		series.str("");
		series << pre_series << "_" << i;
		((CSeries)m_chart.Series(i)).SetTitle(series.str().c_str());
		for(int j=0;j<10;j++) {
			label.str("");
			label << pre_label << "_" << j;
			color = ((CSeries)m_chart.Series(i)).GetColor();
			((CSeries)m_chart.Series(i)).Add(j+i, label.str().c_str(), color);
   // Everything works fine up to here and the chart displays the data points as expected.
	// !!! This next call is where the "Invalid class typecast" message is generated.
	CLineSeries a_line_series = ((CSeries)m_chart.Series(0)).GetAsLine();
Is there another way for me to do this so that I can retrieve a CLineSeries object?
Post by Pep » Tue May 13, 2008 6:22 am
using the following code works fine here :
	m_chart.AddSeries(0);  //line series
	m_chart.Series(0).FillSampleValues(5);
	CLineSeries series = m_chart.Series(0).GetAsLine();
	series.GetLinePen().SetWidth(5);
jonnyg
Post by jonnyg » Tue May 13, 2008 3:43 pm
The following code also works fine on my computer and my friend's:
println("hello world");
I don't think that FillSampleValues(5) will do me much good. Are you saying that the code I'm using to populate the graph data is incorrect? If so, please let me know. Did you try running the code that I sent?
John G
Post by Pep » Wed May 14, 2008 10:49 am
Hi John,
Of course that not, my code was just to check if the same one worked fine on your machine.
Well, forget it all. Looking to all the lines of your last code you send I've seen where the problem is, it's a small mistake. You are trying to assign the Series of the Chart to LineSeries, using the following line :
But at the beginning of the code you add all the series as Point series, instead of LineSeries :
So, you cannot cast directly to lineSeries, if you try to change the above line by :
m_chart.AddSeries(CTchart1::scLine);
all should work fine.
