Waterfall plots and z Planes
Mekon
Post by Mekon » Wed Jun 02, 2004 1:11 pm
Hi Pep
Thanks for your reply regarding Z Planes and use of Cursor Control, but I have tried what you suggested for item 4. and the suggestion does not appear to work. All it does is to add an additional 256 empty points to the 256 points plotted. Each of the data points represents a bucket of width 1.953 and therefore 256 * 1.953 = 500 hence the X axis scaling. So the graph being plotted has only 256 points but the X axis needs to be annotated from 0 to 500. So in effect I need to scale the 256 points to 500 not add an additional .
As part of what I am trying to do
I have a data file containing (256 data points) * 10 which I am trying to plot using the Tchart waterfall plot. Z plane code not shown.
The code I have written to do this is as follows:
' Add point to chart
With TChart1.Series(0).asWaterfall
For X = 0 To NumXValues ‘(255)
Line Input #fileno, YVal
.AddXYZ X, YVal, Z, "", clTeeColor
Next X
End With
If EOF(fileno) Then GoTo labelX
This above code appears to work correctly, but when I use the following code the waterfall does not plot at all.
For X = 0 To int(256*1.953) step 1.953 ‘ plot 256 points at X interval 1.953
Line Input #fileno, Yval ‘ fetch value from data file.
Next X
End With
Can you explain what I am doing wrong. Is it that X has to be an integer and be consecutive ??? e.g 1,2,3, not 1,3,5,etc.
Your help would be appreciated.
Post by Pep » Thu Jun 03, 2004 7:27 am
You can use non-integer values with 3DSeries if you set IrregularGrid to True before to add the Data, e.g.
.IrregularGrid = True
For X = 0 To int(256*1.953) step 1.953 ' plot 256 points at X interval 1.953
Next X
End With
