Multiple series in one file/stream
marksonbase
Post by marksonbase » Thu May 13, 2004 11:29 pm
I would like to know if it's possible to create one file that would contain all of the series data in it (10 or more series), and then load it in. I realize that a .tee file does this, but I need a file format that I can create programmatically on the fly (such as XML... from what I can tell TeeChart can't import XML, but rather, only exports XML). Or is there a spec for creating .tee files?
Basically, I would like to send one stream from a URL that contains the data for all of the series, rather than a separate stream for each series.
Thank you for your help.
Post by Christopher » Fri May 14, 2004 6:09 am
You can create tee files programatically as well, e.g.
Private Sub Command2_Click()
With TChart1
    .Export.asNative.SaveToFile "C:\TEMP\test.tee", True
End With
Thank you!
http://groups.google.com
http://codenewsfast.com/
marksonbase
Post by marksonbase » Mon May 17, 2004 7:19 pm
Thanks for responding Christopher.
Actually, though, I meant that I need to create an 'import' file from scratch (the data has not previously been in a TeeChart control). I need to pull the data from a database (all multiple series of it), and then jam it into one file that the TeeChart control can read.
Is this possible?
Mark
Post by Christopher » Wed May 19, 2004 8:11 am
Hi Mark --
Is this possible?
Sure; you can import XML data using the SeriesXMLSource component ... see the TeeChart AXv6 Feature Demo under:
Welcome! -> New Features -> New Components -> XML Import source
Thank you!
