How can I dynamically (as the cursor is moved over the chart) display the values of the x and y points values in a text block on the chart. An example would be much appreciated.
Serge
Dynamically displaying x,y values
Hi --
Try something similar to:How can I dynamically (as the cursor is moved over the chart) display the values of the x and y points values in a text block on the chart. An example would be much appreciated.
private void Form1_Load(object sender, System.EventArgs e) {
points1.FillSampleValues();
annotation1.Active=false;
private void tChart1_MouseMove(object sender, System.Windows.Forms.MouseEventArgs e) {
int clicked = points1.Clicked(e.X,e.Y);
if(clicked!=-1){
annotation1.Active=true;
annotation1.Text = "XValue: " + points1[clicked].X.ToString() + " YValue: " + points1[clicked].Y.ToString();
else {
Thank you!
http://groups.google.com
http://codenewsfast.com/
