nefis
Post
by nefis » Wed Apr 14, 2004 5:56 am
if in code of my previous post "TrendLines Issues" the command button event handler replace with code below it crushes the app and sometimes Windows.
nefis
Private Sub Command1_Click()
Dim lt As TeeChart.IDrawLineTool
Dim L As Long
Dim L2 As Long
If Xd = 0 Then
Xd = TChart1.Axis.Bottom.Maximum - TChart1.Axis.Bottom.Minimum
End If
If Yd = 0 Then
Yd = TChart1.Axis.Left.Maximum - TChart1.Axis.Left.Minimum
End If
Set lt = TChart1.Tools.Items(TChart1.Tools.Add(tcDrawLine)).asDrawLine
With lt
L = .AddLine(0, 0, 1, 1)
lt.Lines.Items(L).StartPos.X = TChart1.Axis.Bottom.Minimum + Rnd * Xd
lt.Lines.Items(L).StartPos.Y = TChart1.Axis.Right.Minimum + Rnd * Yd
lt.Lines.Items(L).EndPos.X = TChart1.Axis.Bottom.Minimum + Rnd * Xd
lt.Lines.Items(L).EndPos.Y = TChart1.Axis.Right.Minimum + Rnd * Yd
L2 = .AddLine(0, 0, 1, 1)
lt.Lines.Items(L2).StartPos.X = lt.Lines.Items(L).EndPos.X
lt.Lines.Items(L2).StartPos.Y = lt.Lines.Items(L).EndPos.Y
lt.Lines.Items(L2).EndPos.X = lt.Lines.Items(L).EndPos.X + 1000 * (lt.Lines.Items(L).EndPos.X - lt.Lines.Items(L).StartPos.X)
lt.Lines.Items(L2).EndPos.Y = lt.Lines.Items(L).EndPos.Y + 1000 * (lt.Lines.Items(L).EndPos.Y - lt.Lines.Items(L).StartPos.Y)
lt.EnableDraw = False
End With
Call TChart1.Repaint
the changed part
Post
by Christopher » Wed Apr 14, 2004 1:39 pm
Hi --
I'm afraid I can't reproduce this behaviour here using Visual Studio 6.0 SP5, Windows v.5.2.2790 and TeeChart AXv6.0.0.4.
nefis
Post
by nefis » Thu Apr 15, 2004 6:26 am
I use Windows ME and the rest is the same.
Could you try bigger numbers?
lt.Lines.Items(L2).EndPos.X = lt.Lines.Items(L).EndPos.X + 100000 * (lt.Lines.Items(L).EndPos.X - lt.Lines.Items(L).StartPos.X)
lt.Lines.Items(L2).EndPos.Y = lt.Lines.Items(L).EndPos.Y + 100000 * (lt.Lines.Items(L).EndPos.Y - lt.Lines.Items(L).StartPos.Y)
Additionally, sometimes the extension line has different slope so the angle between it and the "main" is not 180 degrees.
nefis
Post
by Christopher » Thu Apr 15, 2004 8:52 am
Hi --
I tried values of 10000000 without getting a crash.
At 100000 this did not occur, at 1000000 it did. How will this problem affect your code practically?
nefis
Post
by nefis » Thu Apr 15, 2004 9:51 am
I'm trying to project the extension as far as possible.
1'000'000 has no sence indeed. But even 1'000 causes either a crush or a wrong slope of the extension line on my system. Even 10 works well but it's unacceptable for my purpose.
nefis
Post
by nefis » Thu Apr 15, 2004 10:01 am
the crush happens in Windows DIB Engine (DIBENG.DLL)
maybe you need to try reproduce the crush on WinME system
Post
by Christopher » Thu Apr 15, 2004 10:56 am
Hi --
Mmm ... try doing a search for DIBENG.DLL on Google and have a look at the first two links which are to support.microsoft.com. Maybe this error is associated to one of these two recognised problems? You'll like the workaround to the Age of Empires problem
nefis
Post
by nefis » Sun Apr 18, 2004 1:25 pm
the crush is caused by IDrawLineTool Selected property.
since it's on your fix list the issue can be dropped for now.
but i don't like to know that the slope of line is not what one can expect
nefis
nefis
Post
by nefis » Mon Apr 19, 2004 3:12 pm
unfortunately, the last build doesn't fix any TrendLine issues.
nefis
Post
by Christopher » Tue Apr 20, 2004 6:37 am
Hi --
This property is not in any of the code mentioned in this thread.
Maybe you are referring to the problem we discussed on:
http://www.teechart.net/support/modules ... pic&p=2199
The slope problem is related to a Windows DIB Engine (DIBENG.DLL)
problem in WinME and cannot be reproduced on any other platform.
Which build are you referring to here and to which problems?
