chart synchronization
We have a chart with multiple series. Each series contains 19 points (18 indexes). when i click on the edge of a series the OnClickSeriesTChart captures a click on index 17. only when i move the mouse slowly and very delicately and click on the series' edge, do i get notify on a click on the 18th index.
Can you help me resolve this issue?
Teechart version (6.0.4)
which series type are you using ? Does this happens using for example a Point series type ? I think the problem is that if you're using a line series the index of each point goes from point to point so the index of the last point is just a litle portion.
Pep Jorge
http://support.steema.com
Hi --
Using TeeChart AXv6.0.0.4 the following seems to work OK here:We are using a line series... So how can we avoid this behavior?
Private Sub Form_Load()
With TChart1
.Aspect.View3D = False
For i = 0 To 5
.AddSeries scLine
.Series(i).FillSampleValues 19
.Series(i).asLine.Pointer.Visible = True
Next i
End With
Private Sub TChart1_OnClickSeries(ByVal SeriesIndex As Long, ByVal ValueIndex As Long, ByVal Button As TeeChart.EMouseButton, ByVal Shift As TeeChart.EShiftState, ByVal X As Long, ByVal Y As Long)
Label1.Caption = "Series " & SeriesIndex & " ValueIndex " & ValueIndex
Thank you!
http://groups.google.com
http://codenewsfast.com/
Here are my results:
when i set the pointer visibility to true, the correct index is returned, while when it is invisible, i keep getting the one before last ValueIndex index instead of the last one.
why is it so? is it possible to get the same result even if the series pointer is invisible?
Further to that, as far as i understood from the documentation, when you click near a point, you get the index to the closest point - this isn't the case both when the pointer is visible and invisible. when i click near the last point, i still get information about the previous one...
Ariel
Ariel
Hi --
This is because the first line (between the points 0 and 1) has valueindex 0. The last line, from point 17 to 18 therefore has valueindex 17. When you make the pointers visible this mute point is resolved.when i set the pointer visibility to true, the correct index is returned, while when it is invisible, i keep getting the one before last ValueIndex index instead of the last one.
why is it so?
Thank you!
Hi --
Could you please send me a link to the post in question?I would be happy to get some answers about the other issues i raised in my previous post.
Thank you!
i meant what i wrote here:
Ariel
Ariel
Hi --
Didn't I answer that when I said:
Pointers invisible .. you cannot click on point 18 because the pointer is invisible, so the whole of the last line has valueindex 17.
The problem here is this .. if the first line (between the points 0 and 1) had valueindex 1 then the "problem" would exist at the beginning of the line and not at the end of it, id est .. where is valueindex 0?
Given the impossibility of attaining a compromise position between these two extremes it was decided to name the first line with valueindex 0.
I hope this is clear
So, pointers visible on points 17 and 18. Click on the last pointer and the valueindex is 18; click on the line that leads to it and the valueindex is 17.This is because the first line (between the points 0 and 1) has valueindex 0. The last line, from point 17 to 18 therefore has valueindex 17. When you make the pointers visible this mute point is resolved.
Thank you!
