TrendLine Issues
nefis
TrendLine Issues
Post by nefis » Wed Apr 14, 2004 5:26 am
the form below creates a trendline on "Add Line" button pressing. Then it creates second line which extends the first one. When an user selects the extention line it tries to switch to first (main) line since the latter should be used to handle dragging for both lines.
Firstly, the second line is invisible until the chart is refreshed.
Secondly, switching selection doesn't work
Could you give me a workaround to emulate the needed behavior?
nefis
VERSION 5.00
Object = "{54294AC6-FA71-4C7F-B67C-6C6405DFFD48}#1.0#0"; "TeeChart6.ocx"
Begin VB.Form Form1
   BorderStyle     =   3  'Fixed Dialog
   Caption         =   "Form1"
   ClientHeight    =   9705
   ClientLeft      =   1590
   ClientTop       =   495
   ClientWidth     =   13725
   LinkTopic       =   "Form1"
   MaxButton       =   0   'False
   MinButton       =   0   'False
   ScaleHeight     =   9705
   ScaleWidth      =   13725
   ShowInTaskbar   =   0   'False
   Begin TeeChart.TChart TChart1
      Height          =   9180
      Left            =   0
      TabIndex        =   0
      Top             =   0
      Width           =   13710
      Base64          =   $"Form1.frx":0000
   End
   Begin VB.CommandButton Command1
      Caption         =   "Add Line"
      Height          =   375
      Left            =   12480
      TabIndex        =   1
      Top             =   9300
      Width           =   1215
   End
End
Attribute VB_Name = "Form1"
Attribute VB_GlobalNameSpace = False
Attribute VB_Creatable = False
Attribute VB_PredeclaredId = True
Attribute VB_Exposed = False
Option Explicit
Dim Xd As Double
Dim Yd As Double
Private Sub Command1_Click()
  Dim lt As TeeChart.IDrawLineTool
  Dim L As Long
  Dim L2 As Long
  If Xd = 0 Then
    Xd = TChart1.Axis.Bottom.Maximum - TChart1.Axis.Bottom.Minimum
  End If
  If Yd = 0 Then
    Yd = TChart1.Axis.Left.Maximum - TChart1.Axis.Left.Minimum
  End If
  Set lt = TChart1.Tools.Items(TChart1.Tools.Add(tcDrawLine)).asDrawLine
  With lt
    L = .AddLine(0, 0, 1, 1)
    lt.Lines.Items(L).StartPos.X = TChart1.Axis.Bottom.Minimum + Rnd * Xd
    lt.Lines.Items(L).StartPos.Y = TChart1.Axis.Right.Minimum + Rnd * Yd
    lt.Lines.Items(L).EndPos.X = TChart1.Axis.Bottom.Minimum + Rnd * Xd
    lt.Lines.Items(L).EndPos.Y = TChart1.Axis.Right.Minimum + Rnd * Yd
    L2 = .AddLine(0, 0, 1, 1)
    lt.Lines.Items(L2).StartPos.X = lt.Lines.Items(L).EndPos.X
    lt.Lines.Items(L2).StartPos.Y = lt.Lines.Items(L).EndPos.Y
    lt.Lines.Items(L2).EndPos.X = lt.Lines.Items(L).EndPos.X + 10 * (lt.Lines.Items(L).EndPos.X - lt.Lines.Items(L).StartPos.X)
    lt.Lines.Items(L2).EndPos.Y = lt.Lines.Items(L).EndPos.Y + 10 * (lt.Lines.Items(L).EndPos.Y - lt.Lines.Items(L).StartPos.Y)
    lt.EnableDraw = False
  End With
Private Sub Form_Load()
  Dim i As Long
  TChart1.Aspect.View3D = False
  Call TChart1.AddSeries(scCandle)
  Call TChart1.Series(0).FillSampleValues(100)
  TChart1.Series(0).VerticalAxis = aBothVertAxis
  TChart1.Axis.Left.Labels.Visible = False
Private Sub TChart1_OnDrawLineToolSelectLine()
  Dim i As Long
  For i = 0 To TChart1.Tools.Count - 1
    If TChart1.Tools.Items(i).ToolType = tcDrawLine Then
      If TChart1.Tools.Items(i).asDrawLine.Selected <> -1 Then
        TChart1.Tools.Items(i).asDrawLine.Selected = 0
      End If
    End If
  Next i
  Call TChart1.Repaint
Post by Christopher » Wed Apr 14, 2004 1:35 pm
Hi --
Try:
  Dim T As Long
  Dim L As Long
  Dim L2 As Long
  Dim FromX As Double
  Dim FromY As Double
  Dim ToX As Double
  Dim ToY As Double
  If Xd = 0 Then
  End If
  If Yd = 0 Then
  End If
  With lt
    .EnableDraw = False
    FromX = TChart1.Axis.Bottom.Minimum + Rnd * Xd
    FromY = TChart1.Axis.Right.Minimum + Rnd * Yd
    ToX = TChart1.Axis.Bottom.Minimum + Rnd * Xd
    ToY = TChart1.Axis.Right.Minimum + Rnd * Yd
    L = .AddLine(FromX, FromY, ToX, ToY)
    FromX = lt.Lines.Items(L).EndPos.X
    FromY = lt.Lines.Items(L).EndPos.Y
    ToX = lt.Lines.Items(L).EndPos.X + 10 * (lt.Lines.Items(L).EndPos.X - lt.Lines.Items(L).StartPos.X)
    ToY = lt.Lines.Items(L).EndPos.Y + 10 * (lt.Lines.Items(L).EndPos.Y - lt.Lines.Items(L).StartPos.Y)
    L2 = .AddLine(FromX, FromY, ToX, ToY)
  End With
Thank you!
http://groups.google.com
http://codenewsfast.com/
nefis
Post by nefis » Thu Apr 15, 2004 6:32 am
hi,
thanks for the workaround, but there is another issue:
try to select the extension line. By code the "main" trendline should be selected but it's not :(
nefis
Post by Christopher » Thu Apr 15, 2004 8:45 am
Hi --
This problem is associated with one that is already on the defect list for TeeChart Pro, meaning that a fix to it will be considered for inclusion into the next maintenance release.
In the meantime, I'm afraid, I can't suggest a workaround to it.
Thank you!
