IDrawLineTool.FromPoint or IDrawLine.StartPos?
nefis
Post by nefis » Wed Mar 17, 2004 7:19 am
what the difference between the properties?
IDrawLine.StartPos (EndPos) set start\end points of corrsponding line.
but what the purpose of IDrawLineTool.FromPoint (ToPoint) properties?
nefis
Post by Pep » Thu Mar 18, 2004 9:59 am
Hi nefis,
as you can see in the Help, it says :
IDrawLine
Description
DrawLine is the Line component used by the DrawLineTool to draw custom lines on the Chart.
You can use the Canvas drawing to do exactly the same. Or
uou can also use the DrawLineTool to draw lines programatically.
nefis
Post by nefis » Thu Mar 18, 2004 12:43 pm
but you didn't answer on my question
what the difference between IDrawLineTool.FromPoint (ToPoint) and IDrawLine.StartPos (EndPos) properties?
Actually, I understand what is IDrawLine.StartPos (EndPos) for.
Post by Christopher » Thu Mar 18, 2004 2:19 pm
Hi Nefis,
Actually, we would prefer it if people didn't shout in these forums :) !
Why don't you have a look at the example of these properties in use that can be seen in the AXv6 Feature Demo under:
Welcome! -> Previous version -> New Chart Tools -> Draw Line
Thank you!
http://groups.google.com
http://codenewsfast.com/
nefis
Post by nefis » Thu Mar 18, 2004 6:02 pm
Is that Steema's way to treat customers? Blaming them with "souting" instead of mere answering a quistion?
Have you ever read user's postings?
I've asked a simple question
to your information there is none (nada) examples on IDrawLineTool.FromPoint (ToPoint) properties. Help is no help too
Post by Christopher » Fri Mar 19, 2004 9:52 am
Hi Nefis,
Please find following a VB example of IDrawLineTool.FromPoint and IDrawLineTool.ToPoint
Private Sub Command1_Click()
With TChart1
    If .Tools.Items(0).asDrawLine.Selected <> -1 Then
        Label1.Caption = "FromPoint (" & .Tools.Items(0).asDrawLine.FromPoint.X & " , " _
        & .Tools.Items(0).asDrawLine.FromPoint.Y & ")" & "  ToPoint (" & .Tools.Items(0).asDrawLine.ToPoint.X & " , " _
        & .Tools.Items(0).asDrawLine.ToPoint.Y & ")"
    End If
End With
Private Sub Form_Load()
With TChart1
    .AddSeries scLine
    .Series(0).FillSampleValues 20
    .Axis.Left.SetMinMax 200, 800
    .Tools.Add tcDrawLine
    .Tools.Items(0).asDrawLine.Series = .Series(0)
    .Tools.Items(0).asDrawLine.AddLine 3, 300, 5, 600
End With
These properties are read-only properties which read the StartPos and EndPos of the selected line. The Help file will be updated to reflect this functionality.
Thank you!
nefis
Post by nefis » Fri Mar 19, 2004 4:00 pm
Hi Christopher,
thanks for the answer.
actually, saying that the properties returns end points of currently selected line would do it just fine.
nefis
