Memory not being released
DaveOke
Post by DaveOke » Thu Aug 03, 2006 6:13 pm
We are having a problem when our application that uses TeeChart 7.0.0.8 exits it generates a memory error. TeeChart 5.0 will exit without the memory error.
I have compiled a program that will show how the memory is not being released. Since I cannot post it here is the code to help demonstrate the memory problem. Here are some results:
No controls on the form: Memory holds stable
Only a single instance of the TeeChart 5.0 control: Memory holds stable
Only a single instance of the TeeChart 7.0.0.8 control: Memory jumps at a rate of 1MB / second.
Option Explicit
Sub main()
Dim lIndex As Long
For lIndex = 1 To 1000
Dim lFrm As Form1
Set lFrm = New Form1
Load lFrm
lFrm.Show
lFrm.Hide
Unload lFrm
Set lFrm = Nothing
Next
Form1 contains only a single instance of the TeeChart 7.0.0.8 Control.
Thank your for your help and support,
David Oke
Post by Pep » Thu Aug 03, 2006 9:12 pm
Hi Dave,
would you be so kind to send me a simple sample (with sources) with which I can reproduce as is the problem here ?
You can send me it directly to pep@steema.com
DaveOke
Post by DaveOke » Tue Aug 08, 2006 2:21 pm
Sent!
Thanks for your help,
Dave
DaveOke
Post by DaveOke » Thu Oct 05, 2006 8:07 pm
Has this issue been resolved?
Post by Pep » Fri Oct 06, 2006 4:36 pm
Hi Dave,
yes, it has been fixed. I think Marc sent directly to your mail a fixed ocx yesterday. If you've not received let me know and we'll send to you again to be able to test it.
