Out of system resources error using TeeChart in ASP page
Tor
Post by Tor » Fri Sep 08, 2006 2:51 pm
In v7.0.0.3 Release notes the following bug is described:
"Resource issue when resizing TeeChart in a browser page during cascade/un-cascade operations whilst having open several/many such pages"
We are currently running v7.0.0.5 and face the same problem.
Have you found a fix for this in a newer release?
Post by Pep » Tue Sep 12, 2006 10:05 am
Hi Tor,
this problem has been fixed in the v7.0.0.8.
Tor
Post by Tor » Tue Sep 12, 2006 3:32 pm
I have now tried to install the latest version (7.0.1.1) and it actually made things worse. It now crashes much more frequently than with the previous version.
We are using the TChart1.Environment.InternalRepaint method on resize events and that used to prevent the teechart control from crashing in most cases, but in the new version this method does not seem to work properly.
Post by Marc » Mon Sep 18, 2006 9:18 pm
To confirm we're checking the same issue, please could you confirm the steps you take to generate the problem and the error message received. After how many operations do you expect to see an error? Does it vary between machines?
If you have a sample page that easily reproduces the problem please could you post it for us to the Steema attachements newsgroup at:
news://www.steema.net/steema.public.attachments
With thanks.
