how to export stream to a file ( appending to file ..)?
Aravind
Post by Aravind » Fri Aug 18, 2006 10:36 am
i would like to export the stream from the chart to a existing file ,
file contains to xml information and i would like to append the chart stream on the same file ...? how can i do that
and also i have a database field of type memo , i store the stream in that field and when restore the value from database to the chart i am not getting the extact content of the stream ... how do i can solve this problem ...?
however main concern is to add the chart stream to the existing file ...?
pls advise me
aravind
Post by Pep » Mon Aug 21, 2006 12:21 am
Hi Aravind,
Which are the differences ?
There's not a way to do this automatically, you'll have to do it manually (saving it to other file, read and append the existing file).
Aravind
Post by Aravind » Mon Aug 21, 2006 9:18 am
1. I STORE THE CHART STREAM IN THE MEMO FIELD OF THE ACCESS DATABASE AND TRIED TO RELOAD THE stream TO THE CHART .
WHEN I RETRIEVED THE VALUE FROM THE DATABASE AND LOAD THE STREAM INTO THE CHART. CHART WAS NOT SHOWING ANY THING ...?
CAN I STORE THE STREAM IN THE DATABASE OR NOT ..? if we are able to store in database , then send me example how to handle the stream with out loosing its settings and data.
2. adding the chart tee file to the existing text file ( appending)...
tee file contain the different characters , even though i used line by line read and append in the existing file , when i extracted the tee file to load on to tchart , tchart was not showing correct values or data...
my objective is either one of the above implementation , if it is a database then it will be wonderfull but none of above resulted in the expected desired output
Post by Pep » Mon Aug 28, 2006 10:09 am
Hi Aravind,
1) You can see one example which shows how to do this under :
D:\Program Files\Steema Software\TeeChart Pro v7 ActiveX Control\Examples\Visual Basic\Visual Basic 5 & 6\Database BLOBs
2) ok, check the above example and if it doesn't help to your requeriments we can try to find a solution.
