Export part of the data?
David
Post by David » Wed Jul 19, 2006 10:50 am
If there are sereval series in a chart and I would like to export only part of them, say from point 20 to 100 out of 200 points. Is it possible to do it?
Thank you very much!
David
David
Post by David » Mon Jul 24, 2006 1:04 am
Any suggestion?
Post by Pep » Mon Jul 24, 2006 7:08 am
Hi David,
the only way I can think of is to create a temporary Chart with the Data you want to export (extracting them from the original Chart) and then do the export of this Chart.
There's not an option to do this automatically.
David
Post by David » Mon Jul 24, 2006 8:26 am
Hi, Pep,
Would you please provide some code how to do that? Add a chart with SetActive(FALSE)?
David
Post by Pep » Mon Jul 31, 2006 9:44 am
Hi David,
you could use similar code to the following :
Private WithEvents tmpChartObj As TeeChart.TChart
Private Sub Command1_Click()
  Set tmpChartObj = CreateObject("TeeChart.TChart")
  With tmpChartObj
    .ClearChart
    .AddSeries (scLine)
    startpoint = 20
    endpoint = 100
    For i = startpoint To endpoint
      .Series(0).AddXY TChart1.Series(0).XValues.Value(i), TChart1.Series(0).YValues.Value(i), "", clTeeColor
    Next i
    .Export.asText.SaveToFile "c:\temp\chart.txt"
  End With
David
Post by David » Mon Jul 31, 2006 10:06 am
Hi, Pep,
I am trying to translate your code into C++ code as below.
CTChart m_chart1;
m_chart1.CreateObject();
m_chart1.ClearChart();
m_chart1.AddSeries(scLine);
Did I translate it correctly? If I use the CreateObject(), do I still need to add a TChart object into the dialog?
David
Post by Pep » Tue Aug 01, 2006 11:15 am
Hi David,
I'm not very familiar with vc++ but you should be able to create it as other standard components. You could create both the original and the temporal used to export specific data at runtime. To create it and add it to the dialog you should use similar code to the following :
   CRect m_Position;
   m_Position.left = 0;
   m_Position.top = 0;
   m_Position.right = 200;
   m_Position.bottom = 200;
   if (m_Chart.m_hWnd == NULL)
      m_Chart.Create("TCHARTWINDOW",NULL,m_Position,this,1001);
