OnBeforeDrawSeries
Vivo
OnBeforeDrawSeries
Post by Vivo » Tue Jun 27, 2006 11:05 pm
How do I know which series is about to be drawn?
I though that it would be passed. I actually thought that I had seen it some where that it was, but I cannot seem to find that reference.
Adrian
Post by Narcís » Wed Jun 28, 2006 10:08 am
Hi Adrian,
This event is called before the chart paints all series, as you can see in TeeChart's help:
BeforeDrawSeries event is called just before the Series points are painted.
WARNING:
Do not change Series properties that would force the Series to be repainted.
This may cause recursion and endless repainting !
What are you exactly trying to achieve with that? We can try to give you an alternative to achieve what you need.
Vivo
Post by Vivo » Wed Jun 28, 2006 1:34 pm
I am trying to have a background for each axis that I can turn on and off at will.
Adrian
Post by Narcís » Wed Jun 28, 2006 1:46 pm
Hi Adrian,
Will this depend on the series visible on the Chart? Could you please be more explicit about what are you trying to achive?
BTW: Have you thought about using TeeChart's OnAfterDraw event? A TChart1.Environment.InternalRepaint call may be sometimes necessary to trigger the event.
Vivo
Post by Vivo » Wed Jun 28, 2006 7:49 pm
I have multiple axes that I move around independently of each other. I wish to put a background on each. I have been trying to use the ColorBand, which would work sufficently for part of the application, but I would also want to display a box underneath series higer in the z order but above other series lower in the z order.
Example:
I'm showing this in a code block as it uses a monospaced font.
            <--- Back of screen               Front of screen --->
                  Lower z-order               Higher z-order
         Panel  axis-a   series-a   box-b axis-b   series-b   axis-c   series-c
      OBDC    OBDS    OBDS       OBDA           OBDS       OBDA     OBDS       OADC
NOTE: The arrows are to indicate where in the z-order the callback functions are called. The callback functions are as follows:
  • OBDC - OnBeforeDrawChart
    OBDA - OnBeforeDrawAxis
    OBDS - OnBeforeDrawSeries
    OADC - OnAfterDrawChart
I want box-b to be drawn after series-a but before axis-b. However, what I am getting from you is that the z-order is as follows:
            Panel   axis-a axis-b axis-c   series-a series-b series-c
         OBDC    OBDA                   OBDS                         OADC
Which may be a problem.
I have thought of it but it will cause unwanted overlapping. Unless I cannot find any other way, I will have to rethink how this will be displayed. Do you have any other suggestions?
Adrian
Vivo
Post by Vivo » Wed Jul 05, 2006 3:10 pm
Will someone please state if what I am saying in the previous post is right or wrong?
Adrian
Post by Pep » Mon Jul 10, 2006 8:40 am
Hi Adrian,
In that case, a trick could be to use a Shape series (with rectangle style), you can add it just before the series you want to keep on top (or change order when you want).
