Chart multiple numeric points based on Date Time
kblum
Post by kblum » Tue May 30, 2006 5:54 pm
I have the following data that I need to display on one chart (line chart I think)...
timestamp charge pump setpoint
5/12/2006 10:36 49.62 22.21 30
5/12/2006 10:38 20.63 21.81 30
5/12/2006 10:40 -30.38 22.51 30
5/12/2006 10:42 -46.38 22.54 30
5/12/2006 10:44 -67.38 22.51 30
5/12/2006 10:46 -77.12 22.51 30
5/12/2006 10:48 -75.38 22.51 30
5/12/2006 10:50 -82.75 22.51 30
5/12/2006 10:52 -83.38 22.54 30
5/12/2006 10:54 -82.75 22.51 30
5/12/2006 10:56 140 21.23 30
5/12/2006 10:58 95.13 17.9 30
5/12/2006 11:00 40.38 17.44 30
5/12/2006 11:02 1 18.79 30
5/12/2006 11:04 32.38 18.7 30
5/12/2006 11:06 -6.38 19.78 30
5/12/2006 11:08 7.12 21.41 30
5/12/2006 11:10 -32.25 22.54 30
5/12/2006 11:12 -50.12 26.3 30
5/12/2006 11:14 -32.25 28.45 30
5/12/2006 11:16 -52 31.84 30
5/12/2006 11:18 -61.75 35.38 30
5/12/2006 11:20 -57.5 38.39 30
5/12/2006 11:22 -44 41.13 30
5/12/2006 11:24 -57.5 43.96 30
5/12/2006 11:26 -24.25 46.79 30
5/12/2006 11:28 -36 49.4 30
5/12/2006 11:30 -22.38 51.83 30
5/12/2006 11:32 -20.62 54.26 30
5/12/2006 11:34 3.38 55.49 30
5/12/2006 11:36 -37.75 57.77 30
5/12/2006 11:38 -38.38 57.77 30
I want the Timestamp on the Bottom Axis, the Charge on the Left Axis, the Pump on the Right Axis, and the set point to be a horizontal line in the middle vertical position of the chart.
What chart do I use & how do I insert the data? Should I setup a separate series for each column above? Is there an example of this somewhere?
TIA,
Ken
kblum
Post by kblum » Tue May 30, 2006 6:57 pm
Ok, I found out about overlap. Now my only problem is getting the Pump Speed lablels to show up on the right side of the graph. How can I do that? Setting Axis.Right.Visible = .T. does not seem to help.
I figured everything out, by assigning the series to an axis.
Thanks for reading anyway.
Post by Pep » Thu Jun 08, 2006 11:20 am
Hi ken,
ok, I'm glad to know that all your problems has been solved, sorry for delay, if you need any help on something let us know.
