Internet Explorer 7
selectric
Internet Explorer 7
Post by selectric » Thu May 18, 2006 4:53 pm
Does TeeChart Pro ActiveX 7 run under Microsoft Internet Explorer 7?
I have a Windows 2003 server machine with IE7 Beta 2 installed (7.0.5346.5) that fails to graph charts using TeeChart.TChart.7
TeeChart.TeeEditor.7 objects. On other machines running previous versions of Internet Explorer, everything runs OK.
I getting the same results when using the following versions of TeeChart7.ocx:
- v7.0.0.4
- v7.0.0.6
- v7.0.0.7.
Should I expect the objects to be used on IE7 or it is too early yet?
Post by Pep » Tue May 23, 2006 1:58 pm
it should work fine. Which error are you getting ? Does this happens with all the ASP examples included into the TeeChart Pro installation.
selectric
Post by selectric » Tue May 23, 2006 8:23 pm
I have not started investigation yet. I just wanted to find out if there are any known issues with the TeeChart controls running on IE7 before doing any troubleshooting.
The only thinng I know for sure yet is that on IE7 I am getting some junk text on page (see below) instead of a graph when opening the page with IE7.
[quote]`0W TPF0 TChartChart Left Top Width
Post by Pep » Tue May 30, 2006 3:27 pm
this seems to be te resulted stream of the generated Chart. Please check if the examples included into the TeeChart Pro ActiveX installation work fine for you, and of course if you encounter any problem please let us know.
