update chart from a database
samir
Post by samir » Wed Dec 14, 2005 7:55 am
Public i As Integer
Public CON As New Connection
Private Sub Command1_Click()
Set CON = New Connection
CON.Open "Provider=Microsoft.Jet.OLEDB.4.0;data source=" & App.Path & "\" & "TimeStamp.mdb"
Dim rs As New Recordset
rs.Open "Select * from MilliSeconds", CON, adOpenKeyset, adLockOptimistic
rs.AddNew
rs![MilliSec] = Label2.Caption
rs.Update
rs.Close
Private Sub Command2_Click()
With TChart1.Series(0)
' remove previous existing points from the Series
.Clear
' add new points to the Series...
' .Add 100, "Europe", vbRed
' .Add 300, "USA", vbBlue
' .Add 200, "Asia", vbGreen
' .Add 120, "Australia", vbYellow
End With
'End Sub
Private Sub Command3_Click()
TChart1.Series(0).CheckDataSource
' End With
'End Sub
Private Sub Form_Terminate()
'MsgBox "Thanks for using.", , "Thanks"
Private Sub Timer1_Timer()
Timer1.Interval = 1
Label2.Caption = Format(Time, "hh:mm:ss")
'+ ":" + Label1.Caption
'''Label1.Caption = Val(Label1.Caption) + 1
'''If Label1.Caption = 100 Then
'''Label1.Caption = 1
'End If
Call run1
Call run
rs.AddNew
rs.Fields(1) = sec.Caption
rs.Update
rs.Close
Public Sub run1()
If i = 10000 Then
i = 0
Else
i = i + Timer1.Interval
End If
Public Sub run()
sec.Caption = i
Here is the code I am using. I want to update the teechart as the values are being populated in the mdb file. So that the graph is running realtime but with values from the database. Please help have uploaded the project in the public attchments folder..
Samir
samir
Post by samir » Thu Dec 15, 2005 4:22 am
Here is the code I am using. I want to update the teechart as the values are being populated in the mdb file. So that the graph is running realtime but with values from the database. Please help have uploaded the project in the public attchments folder.. please help urgently please
Post by Pep » Mon Dec 19, 2005 10:09 am
Hi Samir,
you will have to use similar code as in the following one :
Dim Data As New ADODB.Connection
Dim rst As New ADODB.Recordset
Private Sub Form_Load()
Data.Open "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" _
               & App.Path & "\AccessTestDB.mdb;Persist Security Info=False"
rst.Open "select * from DataTwo", Data, 1, 1
With TChart1
    .Aspect.View3D = False
    .AddSeries scHorizBar
    .Series(0).DataSource = rst
    .Series(0).XValues.ValueSource = rst.Fields(1).Name
    .Series(0).YValues.ValueSource = rst.Fields(2).Name
    .Series(0).YValues.DateTime = True
End With
  UpdateRecordSet
  TChart1.Series(0).DataSource = rst
Private Sub UpdateRecordSet()
  Data.Close
samir
Post by samir » Mon Dec 19, 2005 11:29 am
Hi need to do this fast line and the x-axis is date time and the yaxis is the values. Have attached my programme in the steems attachments newsgroup please see
Post by Pep » Tue Dec 27, 2005 10:35 am
Hi Samir,
I've modified your example and post it again into the attachments newsgroup.
